programming
Delphi and Saf.li – Easy URL Shortening
URL shortening is key since the invasion of Twitter and Twitter-like microblogging platforms, since they are pretty harsh with length. If you’re following me on Twitter, you probably know that I’m a big fan of Saf.li, BitDefender‘s URL shortening service with a twist.
I have already created a WordPress plugin to automatically twitt my blog posts which relies on Saf.li for permalink URL shortening, and the job seems to be pretty straightforward if you’re using PHP. However, if you’re planning to create a desktop application that, say, processes batches of URLs and transforms them in their diminutive version, there may be implementation issues.
IMG DF9F9E 6CE7EB 187BF4 821298 237D99 AC235A
UPDATE: Saf.li has been discontinued. This product doesn’t work anymore, but information in this post will still be available to serve as proof-of-concept.
Start by creating a new project, and don’t forget to add WinInet to your Uses clause, as shown below:
uses WinInet;
Then let’s proceed further with creating the following function. This will be called with the URL we would like to shorten and will return a string with the shortened URL, as delivered by saf.li.
function GetShortURL(URL: string): string
var
NetHandle: HINTERNET;
UrlHandle: HINTERNET;
Buffer: array[0..1024] of Char;
BytesRead: dWord;
begin
Result := '';
//prepend the saf.li link generation location to the URL
url := 'http://saf.li/create?ws=1&url=' + Url;
NetHandle := InternetOpen('Delphi 5.x', INTERNET_OPEN_TYPE_PRECONFIG, nil, nil, 0);
if Assigned(NetHandle) then
begin
UrlHandle := InternetOpenUrl(NetHandle, PChar(Url), nil, 0, INTERNET_FLAG_RELOAD, 0);
if Assigned(UrlHandle) then
//UrlHandle seems to be valid, let's fetch the output (what saf.li responds, that is)
begin
FillChar(Buffer, SizeOf(Buffer), 0);
repeat
Result := Result + Buffer;
InternetReadFile(UrlHandle, @Buffer, SizeOf(Buffer), BytesRead);
until BytesRead = 0;
InternetCloseHandle(UrlHandle);
end
else
//UrlHandle is invalid, prompt the user about that
raise Exception.CreateFmt('Your URL %s is inaccessible. Please try again', [Url]);
InternetCloseHandle(NetHandle);
end
else
//NetHandle is invalid, prompt the user about that
raise Exception.Create('There is an error with WinInet. Whoopsie daisy.');
end;
This is a typical example of calling the function. Just place on your form two TEdit controls and a button, then define the onClick action of the button as follows:
Edit2.Text := GetShortURL(Edit1.Text);
Now the function will respond with a short link everytime you fill in a regular URL and click on the button.
Note: this work is based on a piece of code released courtesy of Scalabium Software and modified by me to suit the purpose. You are free to use it as you see fit, but please be aware that this snippet is released “as-is” and there are no guarantees as to the functionality and usability of the code.
PS: since the piece of code relies on wininet.dll, which is a significant part of Microsoft’s Internet Explorer, the code will no work on systems that do not have Internet Explorer installed.
Subscribe to Lex Talionis
Get the latest posts delivered right to your inbox
